Programmable Devices
19845 Discussions
Cyclone IV GX DDR
Hi, I´ve been using a DE2-115 with cyclone IV E , and in my project I have a DDR IP that came from a Cyclone GX, apparently the rest of the design is working until the IP circuit, where the output is not as expected, suggesting that the circuit it's not functional. I simulated with the ModelSim and had a good result, but when I run the SignalTap, the output does not have any changes in it's waveform.
My doubt here is, does this DDR IP generated from a GX works in other cyclone ?
Thanks in advance.
I don't have a DE2-115 but I suspect that it is using ALTMEMPHY as the IP for the DDR2. If you are referring to the second device as Cyclone IV GX, then yes, it is using the same ALTMEMPHY IP.
Thanks for your answer, I should have more clear about the second device, the IP generated from a Cyclone IV GX works in a Cyclone IV E?
thanks.
The IP itself (ALTMEMPHY) is compatible so unless Quartus tells of any error during compilation I don't anticipate any issues.
hi I'm sorry but I have a different question:
I have DE2i-150 FPGA which support cyclone iv gx
I want to drive the hsmc with 3.3 v while the vcio of the hsmc is 2.5 v
How can I solve this problem
