i'm performing a board simulation that use a Cyclone IV FBGA-484. I need to simulate an address line (50 ohm impedance trace) from FPGA (pin A9 - IO/DIFFIO_T24n) to an SRAM. The VCCIO is 3.3V for the bank. The net is in the Bank 8 (top bank) so according to IBIS model user guide i need to select a model with <I/O> field that start with "c". What is the best model to use to simulate this net? Do i need a model with the 50ohm OCT? ThanksLink Copied
Hi
Yes you need to model with OCT. You can download the package model specific to the device from website or generate the PIN based model using quartus tool. Check the linkhttps://www.youtube.com/watch?v=izcvszgu2ws https://www.youtube.com/watch?v=46kj1yr2-z4 For simulation the link https://www.altera.com/support/support-resources/download/board-layout-test/ibis/ibs-about_ibis.html Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
