Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
Cyclone IV - Using high impedance in GPIO
I have a project with 14 bidir. I use to test integrated circuits from college.
i use the 36 gpio pins in a protoboard with a flat cable. but when i put the bidir in high impedance, all outputs go to high level (but they continue in high impedance).
Firstly i think the weak pull-up resistor is on (and turn off). After I tried turn off all programmable adjustments. Nothing worked.
I am a computer scientist and maybe my fail is in eletronic level. I don't know.
Any suggestions? What can you do to help me?
Highlighted
What is driving the wire when you put the FPGA pins in high impedance?
Highlighted
--- Quote Start ---
--- Quote End ---
The GPIO is connected to protoboard (flat cable). I didn't understand your question, but nothing is connected between pins and protoboard when are in high impedance.
https://www.alteraforum.com/forum/attachment.php?attachmentid=6918
FPGA >> PIN <> GPIO <> Protoboard
Highlighted
Since there isn't anything else driving the wire, when the bidir signals go into high-impedance state, the status present in the wire is "random".
Highlighted
--- Quote Start ---
--- Quote End ---
So, why can I do?
Highlighted
--- Quote Start ---
So, why can I do?
--- Quote End ---
What's the problem?
If you need them low add very high value pull down resistors from each line to gnd.
Nial
debugmaster,
the question is: what behavior do you need?
