21335 Discussions
Cyclone LUT Performance
Hey,
How can I get LUT performances in various Altera FPGAs, or specifically at Cyclone 3?
--- Quote Start ---
Hey,
--- Quote End ---
what do you mean with "LUT" performance ?
Kind regards
GPK
Hey,
I meant the LUTs Propagation delay.
--- Quote Start ---
Hey,
--- Quote End ---
I assume you would like to know how fast your design could run in a FPGA ? Keep in mind that the LUT delay is only one part of delay. The other part is the routing delay, which is more important in newer FPGA's. Also some parts of your design could be implemented in e.g. DSP block ( Multiplier ...). The best way to find out how fast your design will run is to
run the Synthesis and P&R with Quartus.
Kind regards
GPK
The closest thing you're going to get to a documented number is the Core Performance specifications from the Cyclone III datasheet:
http://www.altera.com/literature/hb/cyc3/cyc3_ciii52001.pdf
Pletz is correct. You really need to compile your design and see how it performs.
Jake
First thing first, Thank you for the help.
Now, My goal isn't to check how fast my design should work,
but to plan my algorithms so they will be able to work at certain
frequency, while trying to work with maximum number of logic levels.
If you got an idea how it could be made, I would be glad to hear.
Thanks again for the help.
--- Quote Start ---
--- Quote End ---
Hi rishum,
in my point of view there is no way to get your required information without a
P&R run. Of coarse you can calculate the delay of nxLUT delay, but you don't know
how your functions will be implemented. Are DSP blocks used? How is routing delay ?
Which speed grade is used ....
Kind regards
GPK
