21600 Discussions
Cyclone V E Uniphy Controller Error 174077
Hello All, I am working with a Cyclone V E development board and I'm having a problem creating the uniphy hard memory controller.
I instantiated the uniphy hard memory controller in Qsys and the system completes synthesis but during fitting I get the following error.
I cannot find any information on this error and I am at a loss as to how to resolve it.
Any help is appreciated. Thanks!
Error (174077): On-chip termination control block "ddr3_test1:ddr1|ddr3_test1_mem_if_ddr3_emif_0:mem_if_ddr3_emif_0|altera_mem_if_oct_cyclonev:oct0|sd1a_0" is associated with conflicting I/Os.
Info (174078): I/O "mem_dm[0]" has voltage "1.35V" and impedance value "40 Ohms".
Info (174078): I/O "mem_dm[1]" has voltage "1.35V" and impedance value "40 Ohms".
Info (174078): I/O "mem_dm[2]" has voltage "1.35V" and impedance value "40 Ohms".
Info (174078): I/O "mem_dm[3]" has voltage "1.35V" and impedance value "40 Ohms".
Info (174078): I/O "mem_dqs[0]" has voltage "1.35V" and impedance value "40 Ohms".
Info (174078): I/O "mem_dqs[1]" has voltage "1.35V" and impedance value "40 Ohms".
Info (174078): I/O "mem_dqs[2]" has voltage "1.35V" and impedance value "40 Ohms".
Info (174078): I/O "mem_dqs[3]" has voltage "1.35V" and impedance value "40 Ohms".
Info (174078): I/O "mem_dqs_n[0]" has voltage "1.35V" and impedance value "40 Ohms".
Info (174078): I/O "mem_dqs_n[1]" has voltage "1.35V" and impedance value "40 Ohms".
Info (174078): I/O "mem_dqs_n[2]" has voltage "1.35V" and impedance value "40 Ohms".
Info (174078): I/O "mem_dqs_n[3]" has voltage "1.35V" and impedance value "40 Ohms".
Info (174078): I/O "mem_dq[0]" has voltage "1.35V" and impedance value "40 Ohms".
Info (174078): I/O "mem_dq[1]" has voltage "1.35V" and impedance value "40 Ohms".
Info (174078): I/O "mem_dq[2]" has voltage "1.35V" and impedance value "40 Ohms".
Info (174078): I/O "mem_dq[3]" has voltage "1.35V" and impedance value "40 Ohms".
Info (174078): I/O "mem_dq[4]" has voltage "1.35V" and impedance value "40 Ohms".
Info (174078): I/O "mem_dq[5]" has voltage "1.35V" and impedance value "40 Ohms".
Info (174078): I/O "mem_dq[6]" has voltage "1.35V" and impedance value "40 Ohms".
Info (174078): I/O "mem_dq[7]" has voltage "1.35V" and impedance value "40 Ohms".
Info (174078): I/O "mem_dq[8]" has voltage "1.35V" and impedance value "40 Ohms".
Info (174078): I/O "mem_dq[9]" has voltage "1.35V" and impedance value "40 Ohms".
Info (174078): I/O "mem_dq[10]" has voltage "1.35V" and impedance value "40 Ohms".
Info (174078): I/O "mem_dq[11]" has voltage "1.35V" and impedance value "40 Ohms".
Info (174078): I/O "mem_dq[12]" has voltage "1.35V" and impedance value "40 Ohms".
Info (174078): I/O "mem_dq[13]" has voltage "1.35V" and impedance value "40 Ohms".
Info (174078): I/O "mem_dq[14]" has voltage "1.35V" and impedance value "40 Ohms".
Info (174078): I/O "mem_dq[15]" has voltage "1.35V" and impedance value "40 Ohms".
Info (174078): I/O "mem_dq[16]" has voltage "1.35V" and impedance value "40 Ohms".
Info (174078): I/O "mem_dq[17]" has voltage "1.35V" and impedance value "40 Ohms".
Info (174078): I/O "mem_dq[18]" has voltage "1.35V" and impedance value "40 Ohms".
Info (174078): I/O "mem_dq[19]" has voltage "1.35V" and impedance value "40 Ohms".
Info (174078): I/O "mem_dq[20]" has voltage "1.35V" and impedance value "40 Ohms".
Info (174078): I/O "mem_dq[21]" has voltage "1.35V" and impedance value "40 Ohms".
Info (174078): I/O "mem_dq[22]" has voltage "1.35V" and impedance value "40 Ohms".
Info (174078): I/O "mem_dq[23]" has voltage "1.35V" and impedance value "40 Ohms".
Info (174078): I/O "mem_dq[24]" has voltage "1.35V" and impedance value "40 Ohms".
Info (174078): I/O "mem_dq[25]" has voltage "1.35V" and impedance value "40 Ohms".
Info (174078): I/O "mem_dq[26]" has voltage "1.35V" and impedance value "40 Ohms".
Info (174078): I/O "mem_dq[27]" has voltage "1.35V" and impedance value "40 Ohms".
Info (174078): I/O "mem_dq[28]" has voltage "1.35V" and impedance value "40 Ohms".
Info (174078): I/O "mem_dq[29]" has voltage "1.35V" and impedance value "40 Ohms".
Info (174078): I/O "mem_dq[30]" has voltage "1.35V" and impedance value "40 Ohms".
Info (174078): I/O "mem_dq[31]" has voltage "1.35V" and impedance value "40 Ohms".
The assignments to the I/O pins for the memory are incorrect for your memory IP configuration. The memory IP should have generated a Tcl script that you can run to set all the assignments correctly (pin_assignments.tcl I believe it's called).
Thank you, I did run the script. The error occurred after running the script.
Any idea which assignments might be wrong?
