21588 Discussions
Cyclone V FPGA SPI Flash programming
FPGA3
We are trying to support the SPI flash programming from our FPGA design ported over from Xilinx device. We couldn't find any demo design.
Meanwhile we tried the JIC programming as well for the N23Q128A device but it failed with following error.
Error (209025): Can't recognize silicon ID for device 1. A device's silicon ID is different from its JTAG ID. Verify that all cables are securely connected, select a different device, or check the power on the target system. Make sure the device pins are connected and configured correctly.
YuanLi_S_Intel
FPGA3
Hi Yuan:
There are 2 particular issues we are needing help with:
1. SPI Programming failure with JIC file. The device seems to be supported in the guide we looked up online.
  • •Not able to program the SPI flash with JIC file
  • •Error (209025): Can't recognize silicon ID for device 1. A device's silicon ID is different from its JTAG ID. Verify that all cables are securely connected, select a different device, or check the power on the target system. Make sure the device pins are connected and configured correctly.
  • •Device is in AS mode - MX25L12833FMI-10Gi
  • •Device configurations tried to generate JIC files are EPCS128, EPCQ128 & EPCQ128A
2. Adding SPI Programming support in the FPGA design
  • Since this is a ported design Current design has SPI programmer RTls available what ways we can use that and assign to the IO since the IO’s are hardened we can’t assign them.
  • Which Ips to use?
  • Also i couldn't find any demo design for this. Any further info/discussion on this will be very helpful.
YuanLi_S_Intel
Please find my response below:
Can you select MX25 when generating the JIC file?
Also, please check the following as stated in the link below:
https://www.intel.com/content/www/us/en/programmable/quartushelp/13.0/mergedProjects/msgs/msgs/epgme_device_siid_error.htm
Which Ips to use?
You cant assign and use the IO which is used as configuration pin. To do flash content updating, you may consider using our IP such as Serial Flash IP for AS mode.
https://www.intel.com/content/www/us/en/docs/programmable/683299/current/using-the-fpga-serial-flash-loader-ip-85096.html
Bruce
FPGA3
Hi Bruce,
I dont see an option for MX25. Here is the snapshot.
YuanLi_S_Intel
Can you click the ... beside configuration devices? Then select MX25 inside.
FPGA3
It just gives me an option for EPCS, EPCQ. Check out the snapshot below.
YuanLi_S_Intel
which quartus version you are using? Can you try with latest quartus version?
