21427 Discussions
Cyclone V GT Programming Sucess in Tool but not working
SoorajSurendran
Hi Team
We have designed one custom Board with Intel Cyclone V FPGA GT with part number 5CGTFD5C5F27C7N.
1. After doing power up, we connected JTAG and tried to program FPGA. FPGA got detected in JTAG Chain and Indicated the part number in Quartus Tool. It got programmed also. Program shown Sucess. In this case program was toggling one Test point. But here Test point is not toggling and always stay in high. Am feeling that FPGA is programming but not getting functional.
2. AS Config method also we tried to program Flash, EPCQ. Here also Flash got programmed and shown the success. After the power cycle , FPGA is not functioning.
In Both cases FPGA is programming and Flash get programming. But Functioning is not happening. Can anyone help on this.
sstrell
What's the HDL design you are trying to implement?  You say you are toggling a test point.  I presume you mean you've made a pin assignment and set an I/O standard for that pin?
SoorajSurendran
Here .. we tried to program an LED blinking. But LED is in continuous ON Stage. Not Flashing. Also we have an 48Mhz crystal, that we tried connecting through FPGA to an test point. In that test point .. also signal is showing always high. Till Crystal to FPGA 48Mhz is coming.  From FPGA to test point signal is always high. Also in Tool all unused pin we tried to pull low and checked on gpio connected to test point. Still test point was giving high. So we are not sure Whether FPGA is getting programmed or not.
But in quartus tool , it is showing as programmed and getting detected in Tool chain. Is there any problem in our Hardware connection.
Attaching one of the code i flashed.
sstrell
Are you using the 48 MHz directly as the clock?  What is the clock in this design?  If it's too fast, you wouldn't be able to see the LED flashing.  Maybe increase your count or use Signal Tap to confirm that the output is toggling in hardware.
SoorajSurendran
Yes 48Mhz we used directly as clock. We have 48Mhz one crystal , another crystal available with 106.25Mhz for Serial Lite, another 64Mhz clock also using. Signal Tap we are not able to get connected .. in this design. After programming we tried to use signal tap but we are not able to see... one doubt is like , in tool FPGA is showing as programmed. So is it really getting programmed ? any hardware configuration we need to change.. please check and suggest...
NurAiman_M_Intel
We sincerely apologize for the inconvenience caused by the delay in addressing your Forum queries. Due to an unexpected back-end issue in our system, your Forum cases, along with others, did not get through as intended. As a result, we have a backlog of cases that we are currently working through one by one.
Please be assured that we are doing everything we can to resolve this issue as quickly as possible. However, this process will take some time, and we kindly ask for your patience and understanding during this period. The cases will be attended by AE shortly.
We appreciate your patience and understanding, and we are committed to providing you with the best support possible.
NurAiman_M_Intel
How do you know the FPGA is not functioning? Any error message?
AIman
NurAiman_M_Intel
We do not receive any response from you to the previous answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
