21324 Discussions
Cyclone V GX: PLL on LVDS banks & fPLL
PascalPolygon
Hello guys,
I am looking to implement DP to MIPI DSI using the Cyclone V GX. I will need to synthesize the MIPI pixel clock from the DP stream using the fPLL. As I have 2 DSI channels I will aslo need 2 PLL's (1/channel). Can the cyclone V GX handle this? Can I use a fPLL and 2 PLL's at the same time?
Pascal.
EngWei_O_Intel
EngWei_O_Intel
Hi Pascal
Thanks for your inquiry.
The Cyclone V device family contains fractional PLLs that can function as fractional PLLs or integer PLLs.
The output counters in Cyclone V devices are dedicated to each fractional PLL that support integer or
fractional frequency synthesis.
We can refer to Table 4 of doc below:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/cyclone-v/cv_51001.pdf
Depends on which member code you are using, there are multiple number of fPLLs can be used.
You can refer to doc below for more Cyclone V PLL information:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/cyclone-v/cv_5v2.pdf
Eng Wei
PascalPolygon
@EngWei_O_Intel
Thank you for the reply. Is it possible to use a mixture of fPLL and integer PLL in the same design?
Pascal.
EngWei_O_Intel
Hi Pascal
Yes you can.
Eng Wei
EngWei_O_Intel
Hi Pascal
We do not receive any response from you to the previous reply that have been provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Eng Wei
PascalPolygon
Hello @EngWei_O_Intel
I think you answered my question. Thank you.
