21615 Discussions
Cyclone V bidirectional half-duplex LVDS?
Dear All,
We are designing a board with a Cyclone V connected to another (already existing) board via a bidirectional half-duplex LVDS link. We would prefer to use only 2 pins of the FPGA to implement both the Rx and the Tx. I tried the following:
  • I defined an ALTIOBUF "As bidirectional buffer", and "Use differential mode". See attached file.
  • I used the IO_STANDARD "DIFFERENTIAL 2.5-V SSTL CLASS I".
  • I instanciate the ALTIOBUF in the natural way:
Ulvds : altiobuf_lvds port map
datain => Tx_data,
dataio => FPGA_PIN_P,
dataio_b => FPGA_PIN_N,
dataout => Rx_data,
oe => output_enable,
oe_b => output_enable
(By the way, the oe_b is the output enable for the complemented signal, or the complement of the output enable?)
It seems that Quartus can compile the design, and the Pin-Out File in the report contains
FPGA_PIN_P : U27 : bidir : Differential 2.5-V SSTL Class I : : 5B : N
FPGA_PIN_N : U28 : bidir : Differential 2.5-V SSTL Class I : : 5B : N
Is it correct? It seems contradictory to the documentation and other posts related to this question (or related to BLVDS).
To be complete: Cyclone V: 5CEBA9F31C8, Quartus Prime 16.1.0 Build 196 10/24/2016 SJ Lite Edition.
Thank you
Yes, this is correct. Another area where Cyclone V differs from previous families. This would not work with Cyclone IV. DIFFERENTIAL 2.5-V SSTL CLASS I cannot be tri-stated there. However, Cyclone IV supports Bus LVDS. Cyclone V doesn't.
You seem to get "oe_b" for free - even if you don't want it. Tie it off low if you're happy using a single ended signal driving "oe".
Cheers,
Alex
Thank you a_x_h_75!
We are happy that it is correct. However, I am not sure to understand the AN522 "Implementing Bus LVDS Interface in Supported Altera
Device Families", on page 6, there is a footnote "DIFFIO_TX pin does not support true LVDS differential receivers". Does it mean that for our purpose one should *not* use DIFFIO_TX pins, but DIFFIO_RX pins work well (can be transmit/receive/be tri-stated). Indeed Quartus selected some DIFFIO_RX pins. Nevertheless it seems that our goal is somehow similar to Bus-LVDS?
You *cannot* use the DIFFIO_TX pins on Cyclone V for differential input signals. These signals connect to the dedicated TX channels. The DIFFIO_RX pins can be used, for output signals, by virtue of their emulated DIFFOUT capability. So, for a bidirectional differential signal you must use a DIFFIO_RX pair.
Cheers,
Alex
Does "emulated DIFFOUT capability" means that we need an "External resistor network"?
See "Cyclone® V Device Family Pin Connection Guidelines - PCG-01014-2.5"
Is it a good idea to put the external resistor network (for output) and use also the differential input?
Thank you
I understand that the Cyclone V BLVDS implementation with differential SSTL IO-standard uses the same termination resistors as the AN522 Cyclone III/IV implementation, 50 ohm near series termination and far differential 100 ohm termination at both bus ends. Optionally bias resistors.
