21611 Discussions
Cyclone V drop-in replacement questions
maiello
Hi, my company has a legacy product built on an Altera Cyclone V 5CEBA5F23C7N device.
We are thinking to swap it for an Altera Cyclone 5CEFA5F23I7N. As we are not going to use the internal memory controller, and as the frequencies at play in our system are not higher than 75 MHz, is the part a valid replacement?
I look forward to hearing news by you.
Best regards.
Marco Aiello.
sstrell
One way to check this is in Quartus.  Add the replacement part to your design as a migration device.  Then in the Pin Planner, you'll be able to identify if there are differences that would prevent drop in replacement in the migration view.  See here:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-qps-design-constraints.pdf
Ash_R_Intel
As the query has been answered by community members, hence...
This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
