Programmable Devices
20704 Discussions
CycloneV :MSEL(4:0) and VCCPGM voltage
AGofs
Good morning ,
I'm working with CycloneV GX at AS (x1 and x4) Standard configuration.
I've read at CycloneV Handbook ,that MSEL(4:0) pins shall be connected to VCCPGM or GND directly. The Voltage value of VCCGM is 3.0/3.3V.
But at the scheme of Cyclone V SoC FPGA Development Kit Board, you can see MSEL(4:0) connected to VCCPGM=2.5V via resistors and switch.
Is it correct to connect MSEL pins to 2.5V?
N.B. I've attached print-screen from the scheme.
HBhat2
New Contributor II
As per all the Intel recommendation documents, VCCPGM must be 3V/3.3V for AS x1, ASx4 configuration.
I am not sure why it is 2.5V in Cyclone V SoC kit. But, in Cyclone V GX Dev kit, VCCPGM is 2.5V, but no support for ASx1 and ASx4 mode.
HPB
JonWay_C_Intel
Hi @AGofs​
If you refer to https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/dp/cyclone-v/pcg-01014.pdf
It states that: Connect these pins to either a 1.8V, 2.5V, 3.0V, or 3.3V power supply
Thus, it is ok for VCCPGM to connect to 2.5V.
HBhat2
New Contributor II
Hi @JwChin​ ,
The above document mentions the possible values for VCCPGM, but it does not talk about in conjunction with ASx1, ASx4 configuration mode.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/cyclone-v/cv_5v2.pdf, page 244, Table 7-2:  says that either 3.3V or 3.0V must be connected if Cyclone V platform supports ASx1, ASx4 mode of configuration.
This table in the handbook is the real cause for the confusion.
With Regards,
HPB
JonWay_C_Intel
Hi @HBhat2-GRL​
You are correct. VCCPGM for 2.5V and below is not supported for AS mode. I stand corrected for my previous answer.
I found a kdb that explains it:
https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/solutions/rd04262013_77.html
Hope this clears all the doubts.
HBhat2
New Contributor II
Hi @JwChin​ ,
Thank you for sharing the kdb. This clears my confusion and it helps me to conclude that for Cyclone V devices, VCCPGM must be connected to either 3.3V or 3.0V for ASx1, ASx4 mode.
WithRegards,
HPB
JonWay_C_Intel
The RS and RP external resistors is to give an effective 100 ohm differential output impedance
AGofs
Thank you ,JwChin for answer about "CycloneV :MSEL(4:0) and VCCPGM voltage" issue!
The issue is clear.
Does your last answer "The RS and RP external resistors is to give an effective 100 ohm differential output impedance" is connected to this issue or to another?
JonWay_C_Intel
Sorry, it is to another thread! :)
