21593 Discussions
DAC5672 Sine output
Hi All,
I am trying to generate a simple Sine wave from DAC5672 on my Hsmc daughter card from Terasic . The NCO i am using is from Open Cores , i works fine in simulation as shown in screen shot attached , But when i connect my scope probes i get distorted output screen shot attached . The DAC and NCO are provided with 100Mhz clock and the required output is 12Mhz , which is in my case is 12Mhz but distorted .
When is connect a simple upcounter , i get a Saw tooth wave output as expected .
Has anyone solved this problem ? is there something i am missing ?
Seems like you're providing wrong input to the DAC. Check if it expects you to give it complement 1s input?
I havent read anything about 14-bit inputs being 1's complement .
The only mention about the inputs is given in the attached screen shot .
The 14-bit digital data input fallows the offset positive binary coding scheme
Your turn to google now.
Really great idea.
Thanks for the guidance, now i need a VHDL function to convert 14-bit std_logic into off-set binary code, any ideas ?
Strange question from FPGA guru :) Seems like You only need to change MSB according to the value... Google for TI DAC interfaces pdf, there's a good explanation and examples.
Here's how i am changing values in VHDL
ADJUSTING_OFFSET: PROCESS(sys_clk, sin_out_reg)
BEGIN
IF reset_n = '0' THEN
sin_out_adj <= (others=>'0');
ELSIF rising_edge(sys_clk) THEN
IF nco_sin_out(13) = '1' THEN
sin_out_adj <= NOT(nco_sin_out)+"00000000000001";
ELSE
sin_out_adj<= '1'& nco_sin_out(12 downto 0);
END IF;
END IF;
-- END IF;
END PROCESS;
But i am not getting a clean sine wave out ?? the frequency of generated signal is correct
see image attached
--- Quote Start ---
BEGIN
ELSE
END IF;
END IF;
-- END IF;
END PROCESS;
see image attached
--- Quote End ---
To change 2's complement to offset binary just invert the sign bit.
sign_inv = not data(13);
data <= sign_inv & data(12 downto 0);
keep this combinatorial to avoid latency problems
--- Quote Start ---
Hi All,
--- Quote End ---
I can not send a private message to ask you a question.
I'm in exactly the same situation how you have resolved the problem?
my email yonatanhanann@gmail.com
