DDR2 TimeQuest
Hi everybody!
I am using the HPCII to control a DDR2 SDRAM with a cyclone III. When I compile the program, comes out the error "Critical Warning (332148): Timing requirements not met". In the time analysis I see a "bad" time slack for a clock generated from the pll of the controller.
How could I fix this problem?
thank you all
