Hi Hi!!
I'am writing a sdc file for my_DDR2 Controller based on xxx_phy_ddr_timing.sdc file! This file comes with the Altera DDR2 Controller. Can somebody tell me why the Altera guys set the max output_delay to (1+tDQSS)*period + board_skew!! Where does the 1+ comes from??? from xxx_phy_ddr_timing.sdc: set_output_delay -add_delay -clock $ckclock -max [round_3dp [expr {($off_tDQSS+1-$t(DQSS)) * $t(period) + $t(board_skew) + $fpga_tDQSS_SETUP_ERROR}]] $dqspin info: Memory clock and DQS schould come at the same time at the MemoryChip. But DQS is allowed to be 25%period before or after the rising edge of clk! tDQSS = DQS rising edge to Clk rising edge tDQSSmin = -0.25*Clk_period (in all DDR2 memory datasheets) before clk tDQSSmax = +0.25*Clk_period (in all DDR2 memory datasheets) after clk thank's for your time!! mLink Copied
