For the DDR3 Memory Controller w/ Uniphy IP (Cyclone V / Arria V family), there are some configuration options in Uniphy IP's GUI in Qsys.
What are these features under Mode Register 2 and what option should I select for each feature? 1. Auto selfrefresh method: Manual or Automatic? 2. Selfrefresh temperature: Normal or Extended? Please provide some guidelines. The AlteraEMIF guide isn't very clear.- Tags:
- ddr3
1) This depends whether you want to manually refresh the memory or allow it to happen automatically. This depends on your requirements. If you don't know I suggest you go for automatic.
2) Are you using an extended (industrial) temperature range FPGA? Cheers, Alex- Mark as New
Hi Alex,
1) I don't want to manually control refresh rate. So I'll set to automatic as you suggested. Does this perform auto refresh or self-refresh? I recall there are two types of refresh when comes to DDR3, one being low-power mode. 2) Yes I'm using I-temp FPGA. I think we'll need double refresh rate due to high oper. temp. Should I set it to "Extended"? Also do I need to reduce the tREFI value by half as well? Thanks!- Mark as New
1) Refer to the "Controller Settings" section - page 3-9 - of the "ddr2 and ddr3 sdram controller with uniphy user guide (https://www.altera.com/ja_jp/pdfs/literature/hb/external-memory/emi_ddr3up_ug.pdf)" chapter of the Handbook. This explains use of both self-refresh and auto-refresh - UniPhy supports both - and discusses, briefly, the use of self-refresh in the context of a low-power mode and auto-refresh for efficiency.
2) Yes. I-temp FPGA, select "Extended". Cheers, Alex
