21611 Discussions
DDR3 Write Leveling and Read Calibration
MATRIX7878
     I was told to repost my enquiry, so I am doing that.  I am creating my own DDR3 controller.  It is coming along well, but I have hit a few snags.  My initialization up to and including the ZQ calibration is done.  The issue then becomes trying to ensure that my write leveling and read calibration are correct.  I have them both written, but I am not confident in them.  Does anyone have any examples?  The Jedec standard for DDR3 is free to download and is also on github.  I have used the standards, but the write leveling is not very well written.  I use VHDL and my chip is a DDR3-1600 one.  My code is attached below.
Thank you,
Drew
AdzimZM_Intel
Hello Drew,
Thank you for submitting your question in Intel Community.
Based on your question, you are developing the DDR3 memory controller and currently facing some issues on the calibration stages.
Unfortunately, I cannot support to review your memory controller code in this thread.
Because of that I will transfer this thread to community support.
Adzim
MATRIX7878
     Yes, I am writing a controller for DDR3 memory and would like to know how the write calibration and read leveling can be implemented.  Thank you for transferring it to the community.
Drew
MATRIX7878
     No one has responded to me with a solution.  Is it possible to have an Intel Engineer help me?
Thank you,
Drew
FvM
DDR3 external memory interface with write leveling needs clock fine delay, e.g. implemented by a delay chain, see e.g. https://cdrdv2-public.intel.com/666668/emi_ip-683841-666668.pdf
I don't recognize a similar feature in your code.
MATRIX7878
     That is what I am trying to figure out.  If I can get an example code, or something similar to how to do it without an IP, that would be great.  I can figure out the delays then when the actual logic is written.
Thank you
