21611 Discussions
DE0-Nano Control Panel connect problem
this is my first time use Altera fpga board, i copy the "DE0_Nano_ControlPanel" folder and try to run the application, it shows connection problem due to two missing file "jtag_client.dll" and "dinkum_alt.all",
after copy two files from installation folder /bin directory, (why they don't include these two files in the folder?, user manual says just copy the folder and run the applicaiton.......)
it shows "quartus_pgm download fail(0 sec), if click "ok",
it shows "download SOPC file (DE0_Nano_ControlPanel.sof) fail!
DE0_Nano_ControlPanel.sof is existing in the folder,
so any idea what is going on there?
Bryce
Bryce,
I had a similar problem to yours. First, I downloaded the newest version of the Control Panel from Terasic. This only marginally helped in that it changed the error message slightly. What my problem was, was that the drivers weren't loaded for the DE0-Nano. It showed up in the device manager as a USB-Blaster. I updated the drivers through the update client in the device manager program by navigating to C:\altera\10.1\quartus\drivers and letting the computer install what it felt was appropriate. I am running windows 7 x64 professional. Hope that helps.
Michael
MGree42
This worked for me on the DE10-Lite board as well.
When I ran this command:
.\bin64\quartus_pgm.exe -m jtag -c USB-Blaster[USB-0] -o "p;C:\Users\Michael Green\OneDrive\Documents\DE10-Lite-v.2.0.3_SystemCD\Tools\ControlPanel\DE10_Lite_ControlPanel.sof"
I got this error:
Error (213013): Programming hardware cable not detected
So with the board connected, I just reran this:
C:\IntelFPGA_lite\19.1\quartus\drivers\DPInst
I then relaunched the control panel and was able to connect to the board
Alzaid
Thanks to you,I was able to solve.
ahmed3
walahy el 3azeem kalam 100%
Thanks! This helped. What a pain. I finally got my first FPGA project to load on the Deo-Nano! Others were saying it couldn't be done on windows 7 easily but this was easy.
Hi guys, I'm have the same problem.
I run Win7 (64bits), and I have followed guiding of miyoung1984.
But I cann't solve this problem.
Pls help me. Thanks so much!
I encountered this problem with my DE2-115 as well. I installed the driver as described above and downloaded the latest Control Panel from Terasic, but ultimately resolved the problem by switching the switch on my DE2-115 from "PROG" to "RUN" mode (somewhat counterintuitively).
If you have the latest Control Panel from Terasic, it will show you the command line it executes to program the device. Run this from the command line and you will receive debugging feedback from the programming tool. In my case the error message I got was:
Error: CONF_DONE pin failed to go high in device 1
Error: Operation failed
Derrick Coetzee
miyoung1984 has the right answer. but remember to 'uninstall' the old driver before you install the new driver
Nothing I do can fix this:
Terasic DE0-Nano Control Panel V1.0.1
jtagserver.exe
The application was unable to start correctly (0xc00007b). Click OK to close the application.
Anyone have an idea?
I'm seeing the same problem, although I'm running Quartus 12.0sp2. Is that compatible with the DE0-Nano Control Panel?
It might also be a problem with the USB-Blaster in general as I'm not able to run nios2-configure-sof from the command line successfully either.
--- Quote Start ---
--- Quote End ---
I found the answer in another thread. The problem is that the Altera JTAG Server service was not running. Guess that's not included/working in the standard Quartus install. If you download the stand-alone programmer (Quartus II Software Programmer - sorry, I can't post links yet) it will install the service and you should be good to go.
I am getting the following error when setting up the control panel.
quartus_pgm download fail (2 sec)
download SOPC file(DEO-Nano-Control Panel.sof) fail
Do I need to connect a usb blaster download cable to set up the DE0-Nano control panel? At the moment I am just using a USB Mini-B cable.
I am getting the same error when setting up the control panel. I cannot seem to make any headway.
I have encounered this problem also.
And i solved this issue by the method provided by "miyoung1984 (http://www.alteraforum.com/forum/member.php?u=68592)". Thanks.
The reason is that i did not install the "Altera USB-Blaster".
The process is : Computer->Propertis->Device Manger-> a yellow mark is found ->" by navigating to C:\altera\10.1\quartus\drivers and letting the computer install what it felt was appropriate."(from miyong1984).
My software version is "Quartus II 13.0 (64-bit) Web Edition".
jjoao
Follow the instructions in this link: http://www.terasic.com.tw/wiki/Altera_USB_Blaster_Driver_Installation_Instructions
For Windows 10, do the following:
  1. Plug the USB-Blaster into your PC.
  2. Open the Device and Printers (Control Panel | Devices and Printers).
  3. Under Unspecified, USB Blaster should be listed. Right mouse click on this and then select Properties.
  4. Select the Hardware tab and select Properties.
  5. A new window should pop up with the General tab already selected. Select Change Settings.
  6. Again a new window should pop up with the General tab already selected. Select Update.
  7. Select Browse my computer for driver software.
  8. Find <Path to Quartus II installation>\quartus\drivers\
  • (Note 1: Your altera file is located at the location you selected when you first installed quartus. The location listed in this document is the default location)
  • (Note 2: Stop at the drivers folder, i.e., do NOT go deeper by opening a folder within the drivers folder)
  1. Select OK. Make sure the proper path was selected then select Next.
  2. If the Windows security window pops up Check the Always trust software from “Altera Corporation”box and select Install.
For Windows 7 and Windows 8, do the following:
  1. Plug the USB-Blaster download cable into the PC. The following will appear on the screen: Device driver software was not successfully install. Select Click here for details.
  2. Select Change settings…
  3. Now cancel this (probably by selecting Cancel)
  4. Open the Device Manager (Windows Key | Control Panel | Device Manage)
  5. Under Other devices, USB Blaster should be listed. Right mouse click on this and then select Update Driver Software…
  6. Select Browse my computer for driver software
  7. Find <Path to Quartus II installation>\quartus\drivers\, then select Next; (Note: Stop at this folder, i.e., do NOT go deeper by opening a folder within the drivers folder)
  8. Check the Always trust … box and then select Install
dadin852
I have the same problem "quartus_pgm download fail"
Because I installed two versions of Quartus, so I kept "Quartus II 13.0 (64-bit) Web Edition" only.
Then I simply reinstall Quartus II 13.0, and the problem was solved!
