Hi
I would like to control DE0-Nano on PC by JTAG UART, also I can command DE0-Nano do something by rs232 UART.
But it seems can't output string through rs232 UART, when JTAG UART is exist in Nios II system.
If I remove JTAG UART IP, the rs232 UART can output string normally.
Is it possible use JTAG UART and rs232 UART at same time?
Setting STDOUT to RS232 UART
Hi @CPaul10,
Per my understanding, output simultaneously to RS232 and JTAG are not possible.
If you do not mind me asking, what would be the use case that required you to do so?
Also for the stdout setting changes to RS232, I believe that is in the BSP editor setting.
Warms Regards,
Thanks for your reply.
My project is work well.
Good to know that it is working now, we would be closing the thread. If you have further queries, Please do post a response in the next 15 days.
After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
Warm Regards
