21333 Discussions
DE2-115 control Via PC
Hi I am new in this environment
my question is how can I use JTAG and transfer commands via C sharp (through buttons), so my board understand which button I pressed, and for example will light the correct LED according to the button I pressed in my PC control unit (which is C sharp form)?
So I need basically 3 things:
1. The code in quartus VHDL - that "understand the data it got"
2. The correct command under the button in C-Sharp -> what to write there ?
3. I guess some DLL in PC that will transfer the C-Sharp press to Jtag in DE2-115
Can any one confirm that I am correct?
Is there any good example for this?
Roee
