Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
DS-5 launching the debugger from the command-line console
Hallo, every one:
I have a big Problem to ask here and i need your help:
We use the Altera Cyclone V SOC(Cortex A9) Chip in our project.
Wenn we work under DS-5. with Debug directly in DS-5 there is no Problem, but i want with DS-5 Command Prompt using "debugger" command to debug our Chip, so i have found some info:
-> debugger --target --script ...
so what should i do with th targt Option? i have tryed with our gdbserver(127.0.0.1:3010), but it do not worked, then i must use a RVC file or what(how can i get the RVC file)? Could someone help me?
Thanks a lot, Guys!
MfG!
wenguo hu
Highlighted
Re: DS-5 launching the debugger from the command-line console
Hi wenguo,
May I know what is the hardware you used? I have a complete working headless command set and I think I can help you on this. First you must tell me what hardware (Chipset and Hardware debugger - USB Blaster or DStream).
Yong
Highlighted
--- Quote Start ---
Hi wenguo,
Yong
--- Quote End ---
Hi, Yong:
The Chipset we use Altera Cyclone V and Hardware Debugger is Altera USB-Blaster
actually we wanne under DS-5 with USB-Blaster to create a .rvc File, but ARM Support says that not worked, one must with DSTREAM. So do u konw onthers Software with that we wanne only our Software Code in Hardware Memory to flashen.
Wenguo Hu
Highlighted
--- Quote Start ---
Hi, Yong:
Wenguo Hu
--- Quote End ---
Hi Wenguo,
Sorry I just saw your post because all the Altera Forum email being treated as spam. I hope I am still helpful to you. If I am not mistaken, you want to work with your USB-Blaster under DS-5 but ARM support claim that you must use DSTREAM.
I managed to work with USB Blaster and USB Blaster II too.
Please let me know if you want to use your USB Blaster hardware and uses DS-5 to flash/debug the chip. It is do able.
Yong
