21602 Discussions
Data request from Flex (Regarding the MPN request)
Nivas
  Good day!!!
            This is Nivas from Flextronics Component Engineering Team.
            Hope you, your family and team are safe in these crazy times. Stay Safe. Let’s pray
             We need some details For the below mentioned part number. Please provide the details as soon as possible because it is an urgent data request from our site.
END CUSTOMER : CISCO
END LOCATION : GUADALAJARA (Mexico)
ITEM_NUMBER
391-CIS-16-101058-01
MANUFACTURER_PART_NUMBER
5CSTFD5D5F31I7N
MPN DESCRIPTION
IC-FPGA,5CSTFD5-7.0,FBGA,896 P,1.0 mm,28nm,1.1 VCORE,YES-JTAG,925.0 MHz,-40 to 100 C
GIVEN MPN IS CORRECT/INCORRECT/INVALID
ORDERABLE MPN
STATUS (ACTIVE OR OBSOLETE OR NRND)
IF NRND, PLEASE PROVIDE LTB & LTS DATE
IF OBSOLETE SUGGEST EXACT ALTERNATE MPN(IF APPLICABLE)
MOISTURE SENSITIVITY LEVEL(IF APPLICABLE)
SMT OR THROUGH HOLE(THT)
PACKING_TYPE (TAPE & REEL,TRAY,TUBE OR BULK)
ORDERABLE MPN WITH T&R PACKING OPTION(IF AVAILABLE IN T&R PACKING OPTION)
CASE SIZE* or PACKAGE
PART MARKING(TOP SIDE MARKING)
ROHS STATUS (5/6 WITH EXEMPTIONS OR 6/6 WITHOUT ANY EXEMPTIONS)
DATASHEET LINK
IF NO DATASHEET, PLEASE CONFIRM GIVEN DESCRIPTION EXACTLY MATCHES WITH THE MPN?(YES/NO)
NurAiman_M_Intel
Thank you for contacting Intel community.
Please see my answer below:
GIVEN MPN IS CORRECT/INCORRECT/INVALID : CORRECT
ORDERABLE MPN:
STATUS (ACTIVE OR OBSOLETE OR NRND): ACTIVE
IF NRND, PLEASE PROVIDE LTB & LTS DATE: -
IF OBSOLETE SUGGEST EXACT ALTERNATE MPN(IF APPLICABLE):-
MOISTURE SENSITIVITY LEVEL(IF APPLICABLE): 3
SMT OR THROUGH HOLE(THT): SMT
PACKING_TYPE (TAPE & REEL,TRAY,TUBE OR BULK): TRAY
ORDERABLE MPN WITH T&R PACKING OPTION(IF AVAILABLE IN T&R PACKING OPTION): -
CASE SIZE* or PACKAGE: Tray size 31 x 31 mm
PART MARKING(TOP SIDE MARKING): -
ROHS STATUS (5/6 WITH EXEMPTIONS OR 6/6 WITHOUT ANY EXEMPTIONS): ROHS COMPLIANT
DATASHEET LINK: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/cyclone-v/cv_51002.pdf
IF NO DATASHEET, PLEASE CONFIRM GIVEN DESCRIPTION EXACTLY MATCHES WITH THE MPN?(YES/NO): -
Aiman
