De10 lite
Zohar1
Hi.
I’m trying to connect my pins to the seven segment display and every time I try to run the sof file the segment doesn’t go on.
I checked the pins correct place.
BXia
You'd better program the default demo's .sof in de10-lite cd-rom, then check if the HEX display normally.
Or maybe your code doesn't work.
sstrell
Without seeing any part of the design, there's really no way to know what's going on.
Is it getting programmed successfully?
Zohar1
Hi.
the code have done seccessfullu compliation and i made the pin connection according to DE10-lite manual.
BXia
How did you assign your input pins? And did you program the DE10_LITE_Default.sof in DE10-Lite CD-ROM/Demonstrations/Default to verify function of the segments hardware?
Zohar1
I don’t know how but I tried to run the sof file in the programmer two time in a row and then it worked.
But anyway thanks for your help
khtan
Hi Zohar,
Sorry for the delay in replying to this case, may I know whether the issue been resolved on your end or do you still require support on your end?
I saw there is a few youtube videos on programming the 7 segment led with de10 lite and also some cases where the 7 segment LED hardware fails on de10lite, does the example design in demo working?
Kian
khtan
Hi Zohar,
I will set this thread to community support since you mentioned that it is working and also thanks to our community people BXia and sstrell for their help in this case. If you have further questions or issues , do create a new thread and we will support you from there. Thanks for using Intel Forums.
Kian
