21597 Discussions
DecCloud FPGA hardware issues
Wei-Chih
Hello Intel devcloud FPGA team
I am still have running devcloud fpga hardwares issue by using qsub( Build and Run the Sample in Batch Mode)
the error massage from .e file shows:
terminate called after throwing an instance of 'cl::sycl::runtime_error'
what(): Native API failed. Native API returns: -42 (CL_INVALID_BINARY) -42 (CL_INVALID_BINARY)
make: *** [run_fpga_hardware] Aborted
After I checked some websites that explain "CL_INVALID_BINARY" error, I think this issue may caused from some problems of FPGA hardwares arria10 and stratix10, right? May you help to fix it?
If you need to check part of my code I can share you.
KennyTan_Altera
Thanks for using Intel community forum,
Kindly expect some delay in the reply due to holiday.
Kenny
hareesh
Hi Wei-Chih,
We found two issues with your name but different case numbers.
  1. OneAPI Devcloud FPGA hardware issues (stratix 10 node) (Invalid Binary)
  2. DecCloud FPGA hardware issues
Can you please confirm to me that both are the same issues or different?
and please share your code.
thanks,
Wei-Chih
