21458 Discussions
Default GPIO status of Cyclone 10 LP
gowtham_m_p
We are using 10CL040YF484C8G in our design. Can you Tell us the default IO status before and after configuration?
As mentioned in Cyclone 10 LP Handbook,
In Section 9.2.2 it is mentioned that before configuration the IO Pins are tri-stated,
but in section 6.3.2 the IO states are mentioned that configured as weak pull-up.
Please clarify the default status of IO pins in cyclone10 LP FPGA.
Thanks and Regards,
Gowtham M P
AqidAyman_Intel
Hi Gowtham M P,
Thank you for reaching out Intel FPGA Community.
I would say, from my understanding, the default I/O status before configuration and after power up is tied to internal weak pull up. The I/O pins will be in tristate condition during the power up is happening.
Aqid
AqidAyman_Intel
As we do not receive any response from you on the previous question/reply/answer that we have provided, please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
