21607 Discussions
Demo Program THDB - ADA HSMC Board
Hey Guys, I'm using an Altera De2-115 Board and a THDB-ADA Hsmc Board. I just tried out the dmeo program, but it seems that it won't work right.
I connected the oscilloscope and I get two added sinus waves(at least I think that). But on the Clock I don't get a good signal so I suppose that also the signal on DA-Channel B is not correct.
i tried do understand the demo program but I'm not a fpga, verilog and so on pro so sorry. Maybe someone could help me or had a pic how the demo program should look like.
BTW: The ada utility program works fine!
Thanks!
could you posta picture of the output wave? I don't know anyti g about the chip, but it could be overshoot. Does the frequency and voltage change anything in the signal's shape?
sure, I attached two pics. The screenshoot from the osci after i run the demo program waveform generator and the second
is the logic analyzer after I did all the steps for the a/d and d/a converter(connect A and B for example etc.)
oh and no it changes nothing
