21324 Discussions
Design FPAG board
I've designed my own Altera FPGA board for personal use.
The following is the detail specification:
FPGA: Cyclone IV GX EP4CGX150DF31
Memory: FLASH, SSRAM
Config.: EPCS128 only(USB Blaster port)
Reference: Altera cycloneIVGX_4cgx150_fpga evalutaion board
I'm making is similar to the Altera demo board except DDR2 and MAX II.
When I omit them, are there any problems running NIOS II on the board?
If there will be SSRAM left, then no. Remember that You need memory to run Nios CPU.
depends the size of your program memory and the ssram size
