I have designed a board with the FPGA 10M04SAU324, and I want it to also be compatible with the 10M08SAU324 and 10M16SAU324. I am using bank 3 for the TRUE LVDS signals. I have noticed that all three FPGAs have the same TRUE LVDS on the same pins, but on the 10M16 the names are different.
If I create a design, would the same firmware work on all three without any changes, or would I need to recompile the design for the 10M16?
Make use of the migration devices feature as you create the design to make sure your pin layout will be compatible. You can add migration devices in Assignments menu -> Devices and verify I/O migration in the Pin Planner: https://www.intel.com/content/www/us/en/docs/programmable/683143/24-2/migrating-assignments-to-another-target.html
We sincerely apologize for the inconvenience caused by the delay in addressing your Forum queries. Due to an unexpected back-end issue in our system, your Forum cases, along with others, did not get through as intended. As a result, we have a backlog of cases that we are currently working through one by one.
Please be assured that we are doing everything we can to resolve this issue as quickly as possible. However, this process will take some time, and we kindly ask for your patience and understanding during this period. The cases will be attended by AE shortly.
We appreciate your patience and understanding, and we are committed to providing you with the best support possible.
Yes, correct. We have the migration compatibility feature in Quartus that you can use to ensure the device is compatible to migrate.
For more information on the vertical migration in MAX 10, you can refer here:
Aqid
