Programmable Devices
19825 Discussions
Difference between EPM7032AETC44-10 and EPM7032AETC44-10N
antofi
I am trying to figure out, if there is a difference between the EPM7032AETC44-10 and the EPM7032AETC44-10N, the only difference that I spotted so far was that one is Rohs compliant while the other isn't. I would be thankful if someone could confirm that those CPLDs are basically the same otherwise.
Thank you
ak6dn
Valued Contributor III
Yes, -N suffix means PbFree ROHS compliant package. Pretty much means the same thing for almost all vendors.
The package mechanicals and internal silicon are exactly the same.
AminT_Intel
Yes you can check the suffix meaning on this website: https://www.intel.ru/content/www/ru/ru/products/programmable/sample-ordering-codes.html?elq_cid=6978...
Other than that the specification for the device with similar OPN is the same.
Thank you.
AminT_Intel
 We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
