21602 Discussions
Difference in internal structure depending on speed grade
tanshio
EP2C35F672C6N and EP2C35F672C8N have different speed grades.
Are the internal structures of these two devices the same?
(The production time is the same.)
ak6dn
Valued Contributor III
There is no physical difference between different speed (ie, 4,5,6,7,etc) and temperature (C,I) grades of the same base device.
They are just based on process and yield characteristics at they time they were fabbed.
So the exact same SOF or POF file could be used without recompilation.
The device JTAG ID does not change between different speed/temperature bins.
In fact the only way to tell the difference is by the physical package marking.
NurAiman_M_Intel
The point given by @ak6dn are correct.
Aiman
NurAiman_M_Intel
We do not receive any response from you to the previous answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
