Does 1SG085HN2F43E2LG must need to connect the PMBUS?
Is it necessary to connect pmbus pin only if tail is - V?
Hi ,
Does 1SG085HN2F43E2LG must need to connect the PMBUS? >> Yes as per the recommendation,
Kindly find the explanation.
Intel Stratix 10 devices will not configure or function correctly if the core voltage is driven by a non-PMBus compliant regulator with a fixed output voltage
page no: 5
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/stratix-10/ug-s10-pwr.pd...
Hi
我看了下这个文档,应该是-v的才必须接PMBUS,-L的应该可以不接对吧?
Hi Rxie ,
Kindly find the my reply below in details.
For Stratix 10 with support for SmartVID standard power ,you must connect the PWRMGT_SCT and PWRMGT_SDA connect to power management bus.
There are other opn in which the power line is fixed, that is L and X , in that there is no support for Smart VID , the power is fixed ,
Kindly find the reference in PCG : PAGE NO:28
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/dp/stratix-10/pcg-01020.pdf
If the OPN have L or x no support for SMART VID , so connection is not required , hope it clarifies
Hi ,
Let me know if you have any confusion in my reply ,
I am strongly recommend to follow the guidelines which present in the pin connection guidelines Pagno:28 about the pin connection.
Hi ,
Kindly let me know, if you need further assistance.
