21497 Discussions
Does Arria F series support JESD 204B?
MK_ABQ
New Contributor III
I would like to know if Agilex F series FPGAs support JESD 204B IP?. If no, then would like to understand why?
skbeh
Hi Sir
You can just launch Quartus Pro software, go to Assignments --> Device, at column 'Tile' will shows the available tiles for each device.
Screenshot an example as below.
skbeh
Hi Sir
Yes, Agilex F-series FPGAs can support JESD204B IP.
Below are the related user guides.
1) Intel® Agilex™ FPGA IP Design Example User Guide
URL: https://www.intel.com/content/www/us/en/docs/programmable/683530/21-3-19-2-0/about-the-fpga-ip-design-example-user-guide.html
2) JESD204B Intel® FPGA IP User Guide
URL: https://www.intel.com/content/www/us/en/docs/programmable/683442/21-3-19-2-0/ip-quick-reference.html
SKBeh
MK_ABQ
New Contributor III
Hi SKBeh,
Thanks for your response. From the second link you have given, it mentions that JESD204B IP is supported by Agilex devices (E-tiles). Attaching image below.
Where can I find if my F-series device has E-tile?. For instance, I am seeing different tiles : R-tile, F-tile, P-tile, H-tile, and E-tile. Is there any document which explains which tiles does F-series devices has?
skbeh
Hi Sir
