21602 Discussions
Does QPP support incremental compilation?
Seadog
It appears that Quartus Prime Pro (ver. 18.0 or later) does not support incremental compilation. The documentation does not discuss incremental compilation, and the Design Partitions Window does not have a field for netlist type. What is the story? Thanks.
KennyTan_Altera
Quartus Prime Pro uses a different synthesis engine thus having a different structure compare to Quartus Prime Std. They will no longer have incremental compilation, you can still set the design partition windows in pro but it will require you to study a different document. You can study this document https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-qpp-block-based-design.pdf if any thing that you don't understand from this document, just give me the question and the page number will do. I will answer it here.
Seadog
Thanks. I was looking at that document, but wasn't sure if it was applicable, since I don't really think of what I am doing as a block-based design.
KennyTan_Altera
Yes, it is block base design. Let me know if you have any further question.
KennyTan_Altera
How is it going?
Seadog
I think I am done with this one, thanks.
sstrell
To learn about the block-based design flows, which really are the replacement for incremental compilation in the Pro edition, start here:
https://www.intel.com/content/www/us/en/programmable/support/training/course/oibbc100.html
#iwork4intel
