I use Stratix V/ Arria10 Device.
I made serdes with ALTLVDS_TX.
I want output tx_outclock of ALTLVDS_TX to pin.
Does tx_outclock of ALTLVDS_TX have to be connected to dedicated clock output pin?
Is a regular I/O ok?
In ALTLVDS_TX case, dedicated clock pin has better Jitter than regular i/o?
As tx_outclock generated from a PLL, it is better to assign to a dedicated clock output pin for better jitter performance and clock specific routing inside the FPGA.
With Regards,
HPB
Thank you HPB
In my case, the outclock divide factor is 2,
then tx_outclock is generated from serdes, the tx_in of serdes is "10101010.."
tx_outclock is one of the serialized data output port of channel.
In this case also, dedicated clock output has better jitter than regular I/o?
JC
TX_outcock is generated by internal PLL itself by taking inclock as the input. The PLL itself divides the reference clock to required frequency and outputs at tx_outclock port. So, in my view, it is better to connect to "PLL_xx_CLKOUT" pin of same bank where tx_out is placed.
With regards,
HPB
Hi ,
I would recommend you to use dedicated clock pins for jitter performance. The jitter level is low for the dedicated clock pins comparing to regular IO.
And I also recommend you to do the compilation on Quartus to make sure that the pins are compact with IO assignments
