Hi I am using 10AX057N2F40E2SG FPGA in our custom board.
I would like to understand,
What will happen if i drive continuous clock to PCIe clock pin, after power ON ?
a)Is the Pin GO BAD if i drive clock for continuously for few days!
b)how much the FPGA PIN is capable for continuous run!
Rajesh
are you asking about REFCLK input of XCVR blocks, connected to PCIe clock in a PCIe application? They can be expected to switch 24/7, they are of course designed for continuous operation, just need to respect voltage ratings.
Thank you for the response
Yes Refclk.
Thanks FVM for answering the question, so do you still have any further question in the case ?
Wincent_Intel
Thanks for confirming the answer in Intel FPGA forum.
Also, thank you FvM as well.
If your support experience falls below a 9 out of 10 using Intel FPGA forum, I kindly request the opportunity to rectify it before concluding our interaction. If the issue cannot be resolved, please inform me of the cause so that I can learn from it and strive to enhance the quality of future service experiences.
Wincent_Intel
