simplex mode in single pair transceiver channel
such as tx support 25Gbps, rx support 28Gbps
E Tile xvr how to support simplex
If I understand you correctly, you are inquiring about simplex TX and RX merging. If yes, for your information, there is no support of merging in E Tile simplex. By default, the unused portion of a channel ie TX/RX will be powered down. Sorry for the inconvenience.
Do you know when this feature would be supported?
I know it is has been supported in H tile now.
As I understand it, I am not aware of any specific plan of supporting merging of simplex in E Tile. Sorry for the inconvenience.
Topic Options
