19974 Discussions
EP1C4F324C8N/EP4CE22F17C8N
MRze
EP1C4F324C8N Sample 1  Lot:S916AF1T0 Date:1913 COO:KR
EP4CE22F17C8N Sample 2 Lot:S112AF0D Date:2107 COO:KR
Please help me check and confirm if the device is present?
AqidAyman_Intel
Thank you for reaching out to Intel FPGA Community.
May you share with us why did you want to check if the device is exist or not? Did you purchased it from Intel Authorized distributor?
Aqid Ayman
MRze
First of all are you an Intel employee? Second, can you help me check it out?
Furthermore, if the device has an invalid batch number on your Intel system.
Is it possible to state that the device is not your Intel device?
AqidAyman_Intel
Yes, I am Intel employee. I have checked with the internal team and both S916AF1T0 and S112AF0D are valid lot numbers in Intel system.
MRze
If you can't find the device in your Intel, it means that the device is not your Intel device?
AqidAyman_Intel
Both of the devices you mentioned earlier are Intel devices based on their lot number where it is valid in our system.
Aqid Aymman
