EP3C16U256C8N
JosephBenedict
We have been asked to verify if part number EP3C16U256C8N falls under the characteristics identified in (a) or (b) or No. Pls confirm asap
Reference to Singapore Strategic Goods (Control) Order 2021, it is noted that the product FIELD PROGRAMMABLE GATE ARRAY (FPGA) is found as one of the dual use goods mentioned with the below characteristics, please confirm whether the product traded for this transaction with RTX has the characteristics mentioned.
https://sso.agc.gov.sg/SL-Supp/S564-2021/Published/20210802?DocDate=20210802&ProvIds=Sc-#Sc-
Field programmable logic devices having either of the following characteristics:
a.
A maximum number of single‑ended digital inputs/outputs of greater than 700; or
b.
An ‘aggregate one‑way peak serial transceiver data rate’ of 500 Gb/s or greater;
Farabi
FPGA also have single ended and differential signal. Which can exceed 700Mbps.
FPGA is not a one way only aggregated transceiver, it has Tx and Rx which can exceed 500Gbps.
So the category neither (a) or (b) .
regards,
Farabi
Farabi
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
regards,
Farabi
