Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
EP3SL150F1152C4N, it's lead free device part, but this device still contains Pb ?
Does solder bump of EP3SL150F1152C4N (D/C 1213) contains lead(Pb) which is under ROHS exemption 15 ?
(RoHS Exemption# 15: Lead in solders to complete a viable electrical connection between the semiconductor die and the carrier within the integrated circuit flip-chip packages)
Is there anyone can advise how many Lead(Pb) are contained in this device under ROHS exemption 15 ? it will be better if you can send Altera Material Declaration for this device.
And it's very urgent, pls reply asap if you have information about that, thank you very much.
For a question like this you will have to contact Altera technical support directly. This forum is user based, and you will not get a (legally binding) answer from here.
