I work with Altera Quartus prime edition.
The device that I use is EP4CE15F23I7.
I would like to know how to change the pin planer in excel and then import it - Based on what I tried this is not working for me.
Hi Idanb,
First, you may export your assignments as csv file, change .qsf to .csv, then open and edit it in excel. After you have done editing, import the csv file into Quartus again.
Ean
Hi Ean,
How to import the csv? to where? can you please be more specific?
Idan
Hi Idan,
Go to Assignments -> Import Assignment -> <select your csv file location>.
Ean
Hi Ean,
When I tried it the import didn't work.
Maybe do you have an exmaple?
Idan
Hi Idan,
As you can see in the file name column, I selected my csv file (testing.csv) . Then click OK to import it.
Ean
Hi Idan,
Do you have any update of your problem?
Ean
Hi there,
We do not receive any response from you to the previous reply that have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread.
Thank you.
Ean
