20704 Discussions
EPCS4SI8N > EPCQ4ASI8N For Old Cyclone FPGA
I'm new here. Looking to migrate from Obsolete EPCS4SI8N to EPCQ4ASI8N and noticed The Fast Read Dummy Cycles is 8 on the new part while it is only 1 on the obsolete part. If I'm running the New Part at slow speeds, do I still need 8 Dummy Cycles or could I get away with 1 Dummy cycle, (due to the much slower clock speed)? Is it really time I'm waiting fore or is they an internal counter that must step thru 8 dummy cycles? All help greatly appreciated.
Mark
You can configure the number of dummy cycles.
Check the link for compatibility and timing information.
https://www.altera.com/en_us/pdfs/literature/an/an727.pdf
http://www.mouser.com/ds/2/612/cfg_cf52012-1098931.pdf
Anand Raj Shankar
(This message was posted on behalf of Intel Corporation)
Thank you. The link to the Altera AN727 does not work, (page not found).
Also, Please keep in mind that I and switching to the EPCQ4ASI8N device, (4AS device).
When you say I can configure the number of dummy cycles, how and where do I configure the number of dummy cycles?
Thanks in Advance.
Mark
Hi Mark,
Please check the table:29 in below link.
Note:Number of dummy cycles. When this number is from 0001 to 1110, the dummy cycles is from 1 to 14.
Check the manual for more information
Anand Raj Shankar
Hi Mark,
Check the Link for more information on EPCQ4ASI8N migration.
https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/an/an822.pdf
Anand Raj Shankar
Hi Mark and Anand,
I have just found out the following part associated with the actual problem in the mentioned AN822 spec:
The dummy clock requirement of the fast read (0Bh) and extended quad input fast read (EBh) commands:
EPCQ—the dummy clock is configurable with the non-volatile configuration register (NVCR). When the EPCQ is used with a Cyclone® V, Arria® V or Stratix® V device, the dummy clock is configured to be 4, 10 or 12, depending on the byte-addressing mode and ASx1 or ASx4 configuration. However, in EPCQA devices, the dummy clock is fixed at 8 and 6 for fast read and extended quad input fast read respectively. Therefore you must regenerate the programming files, such as .pof, .jic, and .rpd.
For further information: AN822 spec, 1.1 Migration Considerations, Operation Commands.
Martin
