21611 Discussions
EPLD EPM9320RC208-15
FLAGADEC
On a obsolete application I success to download the firmware (.pof file) of an EPM9320RC208-15 EPLD.
1_ I would like to know if it possible with the .pof file to determine equations?
2_ Wich component can we use to deal with obsolescence ?
I used MAX+Plus II to save the .pof file. Perhaps I have to generate an another file ?
Thanks for you help.
Best regards.
Franck LAGADEC
THALES DMS FRANCE
Mail: franck.lagadec@external.thalesgroup.com
ak6dn
Valued Contributor III
1) Reverse engineering a .pof file (while technically possible, given enough information) is not possible since Altera/Intel do not provide the tools or information to do so. So the answer is no.
2) EPM9320RC208-15 went obsolete in 2007 per PDN0706. Suggested replacement is EPM570M256C5N which is a superset device (ie, it is NOT in the same package as your EPM9320 device). It is NOT a direct replacement. There is no direct replacement. The EPM570 device would require a new board layout AND software recompilation.
Probably not what you wanted to hear, but that EPM9302 device is REALLY old.
