I'm using Quartus II 13.0SP1, I tried to program the device and i'm having an error. When I use a cheap USBblaster , it pass the jtag chain debugger and I can program the device no problem, but when I use my genuine usb-blasterII, same connections, same wires, same powersupply it fails the jtag chain debugger as well as programming. Sometime it give me unknown_1d or unknown_19.
It detect the device, but can iden it.
any clue?
Thank you for contacting Intel community.
-Can you use the later Quartus version? such as version 20.1?
-Can you delete and reinstall the USB blaster driver? Make sure the driver are install correctly.
-Do you have another genuine USB Blaster to test?
Aiman
Hello Aiman,
* Does is support MAX7000S devices?
* I already tried, even with a fresh Quartus install, no luck. Drivers install correctly, no error,no warning.
* Those programmer are pricey, and i only own one, which is brand new.
thanks,
Marc
After further checking, sorry to tell you that USB Blaster II does not support legacy device such as MAX7000.
We apologize for the inconveniences.
Aiman
Aiman
