Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Honored Contributor I
EQFP pin spacing 0.4mm or 0.5mm?
I am a very newbie to Altera devices.
Now, I'm checking the package dimension of 5M40ZE64C5N
which is EQFP 64pin device.
There are two different descriptions about pin spacing
and I'm confusing.
The altera package document
https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/ds/pkgds.pdf
says the pin spacing is 0.4mm in p57
But in a different document like http://dkc1.digikey.com/jp/ja/tod/altera/max-v-overview/max-v-overview.html
it is "0.5mm EQFP package". I can found the value in other documents.
Does somebody tell me which is correct?
Highlighted
Hi k,
0.4mm pitch is correct, based on a measurement on Altera 5M80ZE64C5N in EQFP64 package.
Martin
Highlighted
Thank you Martin,
There are very few pitch conversion boards available for 0.4mm.
And that is what I am afraid of.
