21611 Discussions
Encryption of FPGA design
ZVere
I'm using the following devices:
5AGXFB1H4F35I3G
5SGXEA3H2F35I2L
5SGXEB6R2F40I2LN
Is it possible to encrypt the firmware running on those devices ?
The goal is to prevent someone to do a "reverse engineering" of the VHDL code.
Thank you,
Zvika
Nurina
Does the above reply help? I believe you are looking for a way to encrypt your VHDL module, not your hardware right?
For Quartus Prime Pro you can use IEEE 1735 to encrypt and decrypt your RTL code.
For Quartus Prime Standard we offer Ampcrypt/Amplic tool to encrypt your RTL code. However you would need to contact your local sales representative to obtain this tool.
Nurina
Nurina
May I know which Quartus version you're using?
Nurina
ZVere
The Quartus version is not a problem.
If required, we can upgrade to any version that supports this feature.
Thank you,
Zvi Vered
ak6dn
Valued Contributor III
Nurina
Nurina
Nurina
Hi, do you have any updates?
Nurina
ZVere
Thank you very much for your reply.
We will soon try it.
Zvi Vered
Nurina
Hi Zvi,
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Nurina
P/S: If you like my comment, feel free to give Kudos. If my comment solved your problem, feel free to accept my comment as solution!
