21345 Discussions
Error (10028): Can't resolve multiple constant drivers for net "FinalHash[63]" at has
can anyone help me with this error? FinalHash[63:0] is only used once in this always block. i can't find any solution with this error.
jd
Error (10028): Can't resolve multiple constant drivers for net "HashFinal[63]" at hashCalc.v(158)
Error (10029): Constant driver at hashCalc.v(3281)
and all the bits in the HashFinal has the same error
indeed your HashFinal is assigned in both comb logic block and sequential logic block. check again.
so i have to remove it in the sequential logic?
--- Quote Start ---
--- Quote End ---
I didn't check the code details, but you can't reset a signal in the always block that is assigned outside of it. Neither it makes sense.
