21595 Discussions
Error (10528): VHDL error at lcd.vhd(135): value "0" is outside the target constraint
I had upload a vhd file, please help me check.
The error is at the line 135 : signal lcd_cmd_ptr : integer range 0 to LCD_CMDS'HIGH + 1 := 0;
I have no any idea about it. Please help me solve it, thanks!
you get this error while simulating or during compilation?
Wheres the testbench?
Just a quick try change X to x
i get this error when i doing full compilation
--- Quote Start ---
--- Quote End ---
the result still same
Info: *******************************************************************
Info: Running Quartus II Analysis & Synthesis
Info: Version 9.1 Build 222 10/21/2009 SJ Web Edition
Info: Processing started: Sat Dec 01 15:14:44 2012
Info: Command: quartus_map --read_settings_files=on --write_settings_files=off lcd -c lcd
Info: Found 2 design units, including 1 entities, in source file lcd.vhd
Info: Found design unit 1: lcd-Behavioral
Info: Found entity 1: lcd
Info: Elaborating entity "lcd" for the top level hierarchy
Warning (10445): VHDL Subtype or Type Declaration warning at lcd.vhd(135): subtype or type has null range
Error (10528): VHDL error at lcd.vhd(135): value "0" is outside the target constraint range (0 to -2147483623)
Error: Can't elaborate top-level user hierarchy
Error: Quartus II Analysis & Synthesis was unsuccessful. 2 errors, 1 warning
Error: Peak virtual memory: 223 megabytes
Error: Processing ended: Sat Dec 01 15:14:45 2012
Error: Elapsed time: 00:00:01
Error: Total CPU time (on all processors): 00:00:01
Error: Quartus II Full Compilation was unsuccessful. 4 errors, 1 warning
I compiled it in modelsim with no error
i compiled it in quartus II 9.1
it no shows error when i click analysis current file, but it shows error when i click start compilation.
try giving LCD_CMDS a specified range, or change the LCD_CMDS_T to natural range instead of integer.
--- Quote Start ---
--- Quote End ---
thank you very much!!! it works!!!
--- Quote Start ---
--- Quote End ---
Thanks, it works!
