Error (37027)
Kvand11
What causes the error message below and what can I do about it?
Info (12128): Elaborating entity "ipx_jp2k_d_top_4K60p" for hierarchy "i_j2k|ipx_jp2k_D_I|ipx_jp2k_top_I"
Warning (292021): Support for IP core ipx_jp2k (5C3E_200D) in device family Arria 10 is preliminary and specifications are subject to change.
Error (37027): Cannot generate Atom Netlist File because device 10AS066N3F40I2SGES is not installed
Error (37003): Can't generate Atom Netlist File for device family Arria 10
The 10AS066N3F40I2SGES is an engineering sample that is not supported in 18.1 as far as I know.
The error message occurs in some projects but not in others even though they are equivalent. How do I get rid of it?
Kvand11
Problem solved. I was using an IP meant for the 10AS066 development board.
Kvand11
