21611 Discussions
Error : Arria 10 emif_reset_ interrupt acknowledge
bkanal
I 'm getting an Emif reset interrupt acknowledge on my board that uses Arria 10 .After receving the error ,the codes does not progress. Therefore it seems to fail DDR calibration .Any ideas on the problem ?
Board : Name
I2C: READY
DRAM :Warning : Caches not enable
emif_reset interrupt acknowledge
aikeu
Hi bkanal,
Is your Arria 10 a custom board? Any different from the normal development kit?
Try to run with pre-built binary from link below and check and see if there is any difference in the outcome:
https://www.rocketboards.org/foswiki/Documentation/Arria10SoCGSRD
Aik Eu
bkanal
Thank you very much for your reply Aik Eu. I will check.
aikeu
Hi bkanal,
Any follow up from the previous comment?
Aik Eu
aikeu
Hi bkanal,
May I know are you still following up with the case?
Aik Eu
bkanal
Hi Aik Eu,
No thanks. We solved it. Thanks for your help.
aikeu
Hi bkanal,
Glad to heard that the issue has been resolved.
I will close the thread then.
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
Aik Eu
