21615 Discussions
Error Code: *** Fatal Error: Int Divide By Zero Module: quartus_map.exe Stack Trace:
Stack Trace:
0x258e4: GEN_MACHINE_INFO::get_cache_size + 0x3b4 (CCL_GEN)
End-trace
I continue to get this error code when trying compile an project. Does anyone no what this means or how can I fix it.
That is a quartus crash. You should report it to Altera.
Yes, Galfonz is right. Quartus II internal error cannot be fixed by user. You need to file case to MySupport and get a patch to workaround it.
