21338 Discussions
Error: Input port must be driven by a non-inverted input pin or another PLL
Hi,everyone.
I used a PLL to generate the special clock,after coplilation,an error occured:Error: Clock input port inclk[0] of PLL "d5m_pll" must be driven by a non-inverted input pin or another PLL, optionally through a Clock Control block.
The code listed:
sys_pll d5m_pll(
.areset(1'b0),
.inclk0(OSC_50_BANK2_in),
.c0(),
.c2(D5M_XCLKIN),//24M
.locked()
OSC_50_BANK2_in is a clock source.
Please tell me how the problem occured and how to solve it,thank you very much。
I'm guessing OSC_50_BANK2_in is assigned to a pin that isn't a dedicated clock input location. Look in the Pin Planner.
Thank you,I will check again.
You are right.I didn't assign to the clock.Thank you very much.
